How do I connect to more remote subnets with SecuExtender IPSec client
OWB
OWB Posts: 46
image  Freshman Member
Today I am using SecuExtender SSL client for remote access to company network, and it handles more subnets just fine, and meet my needs.
However, I would like to switch to SecuExtender IPSec, since it is a more secure solution.
I have managed to setup SecuExtender IPSec so I have access to one of my subnets but cannot figure out how to make a configuration managing multiple subnets. Is that not possible with the SecuExtender IPSec VPN client?
Best regards Ole
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,500
    image  Zyxel Employee
    Hi @OWB,
    It is not fully customizable like the SSL VPN setup, as shown below, is that correct understood?
    Ans: Yes. For IPSec VPN client, you can choose full tunnel mode or split tunnel(for one subnet only).
  • Zyxel_Emily
    Hi @OWB,
    In the VPN Connection, set 0.0.0.0/0 in Local Policy.
    If you use wizard to set up Remote Access VPN, select "Full Tunnel". Then IPSec VPN clients are able to access all subnets.
  • OWB
    OWB Posts: 46
    Hi @Zyxel_Emily
    Thanks’ that did solve my issue.
    So, it is either one specific subnet, or all subnets.
    Best regards Ole.
  • Zyxel_Emily
    Hi @OWB,
