Connectivity Check problems with interface and routing.
PeterUK
PeterUK Posts: 4,719 image  Guru Member
found a problem with my setup found here
Untitled Image
On VPN300 V5.36(ABFC.2)
To start just having ping to 192.168.44.4 in routing rule all is fine I disable VPN link it fails turn back on routing rule enables.
I then add to VLAN443 interface ping check for no-ip.org and bounceme.net with any one respond(s) then disable VPN link this does not fail the routing rule with ping to 192.168.44.4 !
I then go to the routing rule disable ping check then go back and enable it now the rule fails enable VPN link rule enables.
Back to VLA443 disable ping check then disable VPN link routing rule does not disable! I then go to the routing rule disable ping check then go back and enable it now the rule fails enable VPN link rule enables.
