ZYXEL USG FLEX 200 - ENABLE PING BETWEEN LAN 1 AND LAN 2
rafaeldavid_77680
rafaeldavid_77680 Posts: 1 image  Freshman Member
I have a ZYXEL USG FLEX 200 with two LAN :
LAN1 : 172.17.30.0 /24
LAN2 : 172.18.30.0 /24
I can't ping LAN 2 from LAN 1 and LAN 1 from LAN 2, I tried to add Policy Control from LAN 1 to LAN 2 and LAN 2 to LAN 1.
I also add a policy route from LAN 1 to LAN 2 with a SNAT on outgoing-interface.
I tried to put static route.
But the ping stay in "Destination Host Unreachable".
I upgrade my ZYXEL with the last firmware.
Has anyone had this problem before?
Thanks !
Rafaël DAVID
    PeterUK Posts: 4,834
    image  Guru Member
    edited July 2023
    You don't need static route or a policy route if PC's on each LAN have a gateway to go to
    likely the PC firewall is blocking ICMP or device not allowing it to be pinged
