USG 110, remote install printer (autodiscover problem)
Hello, has anyone solved the problem of remote printer/copier installation - when connecting via
SecuExtender is not found device installation program (autodiscover)?
I can manually add the printer and add IP adress printer.
I enabled ports on the firewall: according to table 3 here https://www.cups.org/doc/firewalls.html
So anybody have idea, why AUTODISCOVER search not found device ?
Thank you
Hi @kyssling,
Based on my understanding, most auto-discovery protocols run in broadcast mode, and broadcasts cannot pass through Layer 3 routing.
They only work within the same subnet.0
Maybe AutoDiscover works only on the same subnet?
Hi @kyssling,
- 243 Nebula Ideas
- 6.8K Security
- 781 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
