NWA5123-AC-HD Power supply and PoE at the same time?
Tzunami
Tzunami Posts: 32
image  Freshman Member
edited May 2024 in Wireless
Is it possible to connect Power supply and PoE at the same time?
If yes, which has priority?
NWA5123-AC-HD is managed and connected to a USG 110. PoE injection came from a POE12-HP
  • Zyxel_Kay
    Zyxel_Kay Posts: 1,279
    image  Zyxel Employee
    Hi @Tzunami ,
    Absolutely, you can indeed connect both the power supply and PoE (Power over Ethernet) simultaneously to your NWA5123-AC HD access point. When both power sources are connected, the power adapter takes priority over PoE. In other words, the device will draw power from the power adaptor if it is connected, and only if the power adaptor is not connected will it use the PoE source.
    Kay
  • Zyxel_Kay
    Hi @Tzunami ,
    Kay
  • Tzunami
    Tzunami Posts: 32
    Thanks, Kay :)
