Remote management fails because traffic is directed to wrong ip address
AJS
AJS Posts: 6
image  Freshman Member
edited September 2023 in Security
I want to be able to do remote management over WAN, but the traffic is directed to a wrong ip address (192.168.9.33 instead of the Zywall's ip address 192.168.9.1).
Settings in Config.System.WWW
Security Policy Log
Can anybody tell me how to tell the Zywall it should direct this traffic to the right ip address?
  • AJS
    AJS Posts: 6
    I solved the problem myself. The problem was caused by a NAT rule. After removing this it works like a charm.
