gs1900 8HP after firmware upgrade I can't login in with admin 1234 any longer - help!
Classicm
Classicm Posts: 3
image  Freshman Member
HiHi,
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,242
    image  Zyxel Employee
    Hi @Classicm,
    May I know which firmware version did you upgrade from and to?
    Zyxel Melen
  • Classicm
    Classicm Posts: 3
    Hi, thanks for the reply. I went from V1.6 to V2.7.
  • Classicm
    Classicm Posts: 3
    I have not changed the default admin login/password
  • Zyxel_Melen
    Hi @Classicm,
    Since GS1900-8HP doesn’t have V1.6 firmware, I assume you were using V2.60 firmware. So, I tried to reproduce this problem from V2.60(Patch1) to V2.70(Patch5), V2.60(Patch2) to V2.70(Patch5), V2.60(Patch3) to V2.70(Patch5), V2.60(Patch4) to V2.70(Patch5), but I can still use admin/1234 to log in.
    To fix your problem, please press the reset/restore button in the front panel for 10 seconds to factory default it.
    Zyxel Melen
