FLEX 100H Configuring VoIP/SIP related settings
I'm sorry but we're not able find any VoIP/SIP related configuration settings in the Web admin interface. We're Looking for:
- Enable/disable SIP ALG
- Enable/disable SIP header transformations
- Configuration of SIP Media Timeout / Signaling Timeout
- Enable/disable Anomaly detection and prevention
- Configuration of UDP Session Timeout
If there is no option in the UI, how the commands would be for CLI?
Hi @hli ,
Greeting Forum,
We do not support SIP and sesson timeout functions currently.
But there will be plans to support it in the futureFor ADP, We named "DoS Prevention" , There will be the same settings as ZLD ADP
Thank you
Hi @hli ,
Greeting Forum,
Thank you
Hi Zyxel-Team
Just wanted to ask if the mentioned features are available now in the current firmware version of the Flex H Series?And is there somewhere an updated list of the still missing features (in comparison to the normal Flex Firewalls)?
Hi @hli
SIP ALG function will be supported in the next firmware release which ETA is 2025 Q1.
About the missing features, we currently do not have a list. Would you like to share what feature you are seeking?
Zyxel Melen0
- 243 Nebula Ideas
- 6.8K Security
- 781 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
