USG 100 - SYS Led Blinking - Impossible to reset
Dear sirs,
suddenly my USG 100, bought in 2015, stopped working:
- Impossibile to connect it by ehternet
- All Ethernet Leds are OFF
- Power Led is ON
- SYS Led Continuously Flashing
I tried to unplug and plug ethernet cables, electrical supply but nothing.
I tried also the factory reset by reset button, but the reset doesn't work, the SYS Led still blinking.
Please someone can help me? Is there another way to do a reset?
The user manual says the SYS Led must be off to do a reset but in my case what I have to do?
Thank-you very much
Regards
p.s. I searched before open a new post but i didn't find a solution
Dear Vic,unfortunately I tunred on the Zywall and the Power led has turned red. Hardware issue.Honestly, I am little disappointed, I was hoping for a better quality for this professional device (not yet five years of working) , I was unlucky.Thank-you very much for your supportBest Regards
Hi @Franc
Do you have the console port to connect to your USG100? Can you share with us what information was logged in the console?
By the way, you may try with the recovering procedure mentioned in the firmware release note and see if it helps.
Here I attached release note for your reference.
Dear Vic,thanks for your reply.Are there any detailed instructions to connect by the console port? I have the blue RS 232-Ethernet cable.Thank-you0
Thank-you, I'll try and I'll keep you informed.
- 243 Nebula Ideas
- 6.9K Security
- 794 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
