Wireless Bridge Mode and NWA210AX LAN Port
In Wireless Bridge mode, the NWA210AX and its LAN port are Down often. I need to permanently connect a DVR Recorder via LAN port. Which configuration should I implement? Or, alternatively, which Hardware do you recommend me to use?
My network consists of 2 x NWA50AX, 1 x NWA110AX and 1 x NWA210AX in MESH mode. NWA110AX is the ROOT AP (connected via cable to the POE Switch)
Thank you and best regards
David
Hi @Ceccus
To set up a wireless bridge connection, both of your access points (APs) need to support the wireless bridge feature. Unfortunately, your NWA110AX (root AP) and NWA210AX (repeater AP) do not support the wireless bridge function. As a result, when you establish a mesh connection between the NWA110AX (root) and the NWA210AX (repeater), the LAN port on the NWA210AX will not function.
For more details about the wireless bridge function, you may refer to this article:
Additionally, to ensure the LAN port on the NWA210AX can be used, you can either switch your deployment and make the NWA210AX the root AP, or consider using another model that supports the wireless bridge function. To find out which models support the wireless bridge function, you can refer to the device function table on Nebula CC.
Kay
Hi @Ceccus
Kay
Hi Kay,
Thank you for your very clear answer.
I have currently configured the 2 APs in "Manual Uplink" in Smart Mesh mode with Static IP (DHCP reserved).
At this moment the configuration seems to be stable and LAN 1 port works regularly.
I will check in the future and if there are any malfunctions and possibly replace the 2 APs with the indicated models that support Wireless Bridge functionality.
Thanks againDavid
I have three NWA210AX. all with Ethernet going directly into a switch. is there any means of uniting them into a joint network?
- 244 Nebula Ideas
- 6.9K Security
- 808 USG FLEX H Series
- 392 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
