Zyxel USG20-VPN Enable LAN1 using CLI
Best Answers
I think its
configure terminal interface lan1 no shutdown
Hi @Jeff_ATS,
You may use
show interface allto make sure the interface's name that you disabled and reference @PeterUK's example command to enable.For more information about the CLI command, please reference our CLI reference guide:
https://download.zyxel.com/USG20-VPN/cli_reference_guide/USG20-VPN_V5.37.pdf
Zyxel Melen0
I think its
Hi @Jeff_ATS,
You may use
Zyxel Melen0 -
Thank you all! Took a while to get the correct console cable
Welcome to USGFLEX 50
Username:admin
Password:
Router> show interface all
No. Name Status IP Address Mask IP Assignment
1 wan 100M/Full xxx.xxx.xxx.xxx 255.255.255.248 Static
2 sfp Down 0.0.0.0 0.0.0.0 Static
3 lan1 Inactive 0.0.0.0 0.0.0.0 Static
4 lan2 Down 192.168.2.1 255.255.255.0 Static
5 Classroom Down 192.168.3.1 255.255.255.0 Static
6 Chemical Down 192.168.5.1 255.255.255.0 Static
Router> configure terminal
Router(config)#interface lan1
Router(config-if-lan1)#no shutdown
Router(config-if-lan1)#exit
Router(config)#exit
Router# show interface all
3 lan1 Up 192.168.1.251 255.255.255.0 Static
Router# exit
Username:
- 243 Nebula Ideas
- 6.9K Security
- 792 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
