PCI Compliancy and disabling des,rc4 and 3des
To remove the use of RC4 and DES ciphers run the following commands:
Router#configure terminal
Router(config)# no ip http secure-server cipher-suite rc4
Router(config)# no ip http secure-server cipher-suite des
Router(config)# show ip http server secure status
this does not seem to work I end up with
active : yes
port : 443
certificate : default
force redirect : yes
authentication client: no
strong cipher suite : yes
cipher suite : rc4 aes des 3des
ssl protocol : tls1.2
HI @Ncarbon
Maybe a "write" command should be done before the "show ip http server secure status" command.
https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=016999&lang=EN
Try it, and let us know if it works.
Regards0
- 244 Nebula Ideas
- 6.9K Security
- 801 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 329 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
