PoE12-3PD: Power over Ethernet Extender
Zyxel_Claudia
The PoE12-3PD is a Power over Ethernet (PoE) extender designed to provide extended power and connectivity for network devices, including access points, IP cameras, and IoT devices. This device acts as both a Powered Device (PD) and a Power Sourcing Equipment (PSE), making it a versatile addition to any network infrastructure.
Key Features and Hardware Overview
- Front Panel Indicators:
- Power/SYS LED Indicator: Shows the operational status of the device.
- PoE Max LED Indicator: Displays the remaining power budget.
- Internal Components:
- Reset Button: Located under a detachable cover.
- PoE Ports:
- Uplink Port: Draws power and data from a PoE switch (supports up to 60 watts).
- Three Downlink Ports: Each supports up to 1 Gbps Ethernet link speed and can deliver up to 30 watts per port.
- Power Input and Output:
- Uplink Port: Acts as a PD and requires power input, typically from a PoE switch.
- Downlink Ports: Act as PSEs, providing power to connected devices like access points and IP cameras.
- Power Budget:
- 60 watts input: Up to 45 watts output.
- 30 watts input: Up to 22 watts output.
- 15 watts input: Up to 7 watts output.
- Installation and Usage:
- PoE Standards Supported: 802.3af/at/bt.
- Consumption Mode: Dynamically allocates power based on connected devices' needs.
- Installation: Suitable for outdoor use with IP55 enclosure, surge protection, and a wide operating temperature range.
Practical Applications
- Extending Network Range:
- The PoE12-3PD can extend the range of PoE devices beyond the typical 100-meter limit by inserting it between the PoE switch and the end devices.
- Outdoor Installations:
- Ideal for environments such as gas stations, where network devices are spread over a large area.
- Flexible Power Management:
- Can support a variety of devices with different power requirements, ensuring that the total power budget is managed efficiently.
Additional Features
- Continual PoE:
- Ensures that connected devices remain powered even during software reboots or firmware updates of the PoE12-3PD.
- PoE Budget LED Indicator:
- Provides visual feedback on power consumption and available power budget.
- Companion Management Tool:
- Supported by Nebula cloud management, allowing for easy remote monitoring and configuration.
- Surge Protectors:
- Recommended to use a surge protector for outdoor installations to protect devices from lightning strikes and electrical surges.
Summary
The PoE12-3PD is a robust and versatile PoE extender that supports both indoor and outdoor applications. With its enhanced power management, multiple PoE standards support, and integrated management capabilities, it provides a reliable solution for extending network connectivity and power to various devices.
- 242 Nebula Ideas
- 6.8K Security
- 764 USG FLEX H Series
- 385 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 323 Service & License
- 522 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
