What factor affect a repeater AP select its uplink for build up smart mesh?
Zyxel_Bella
Zyxel_Bella Posts: 603
Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
image  Zyxel Employee
The repeater AP considers multiple factors to select its uplink automatically. It does not solely depend on signal strength (RSSI), though RSSI plays a significant role. Here are the main factors influencing the choice:
  • RSSI Threshold: The repeater AP will select an uplink AP that meets a certain RSSI threshold to ensure a stable connection.
  • Mesh Hops: To optimize performance, the AP considers the number of mesh hops needed. Fewer hops usually result in better performance.
  • Channel Utilization: The AP prefers uplink connections that operate on less congested channels.
  • Ping Packet Count: The AP sends ping packets to potential uplink APs to assess network latency and chooses the one offering lower latency.
  • 5G Radio Preference: The system prioritizes 5G radio for mesh connections due to its higher bandwidth and lower latency compared to 2.4G radio.
