Why is my client speed quite low and AP showing as orange?
Zyxel_Bella
Zyxel_Bella Posts: 603
Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
image  Zyxel Employee
If the AP shows as orange icon with messageLimited Uplink Speed 10/100Mbps, it indicates the uplink network currentlysupports 10/100Mbps transmission speed only.
The devices connect to the AP will face poor speed quality.
Recommended Checks and Actions
  • Check Network Cable: Ensure that the network cable connected to the AP supports 1Gbps transmission speed.
  • Check Connected Devices: Verify that the switch or router port to which the AP is connected supports 1Gbps.
Further Reading
For more detailed steps, you can refer to this article:
Why Did My AP TurnOrange? How to Check AP Status on Nebula?
