Delay after reboot for some routing rules to enable
USG FLEX200HV1.21(ABWV.0)ITS-24WK35-m5760
Seems you have to wait around 5 minutes + after boot lets you login for some routing rules to apply mainly any with incoming set to any
Yes, from my observation, boot times have steadily increased since 1.10. H series doesn't boot faster than previous models, contrary to what Zyxel advertised.
Check the log on the USB to see if you have over 50,000 entries
, , , warn , user , two-factor auth. , , , , Two-factor Auth. daemon: uam_read_event error, ret = -1
Hi @PeterUK,
May I know if this issue still occurs after you upgrade to the latest date code firmware?
Hi @bbp, @HUBERT_KASPRZAK,
Is the FLEX H reboot still slow after upgrading to 1.30? If yes, can I request your configuration to reproduce and check this issue?
Zyxel Melen0 -
Its not so bad now but when SYS stays on you still have to wait a bit for the rules to apply about 60 seconds
In 1.21 it took an extra 5 minutes to load NAT rules. 1.30 seems OK.
- 242 Nebula Ideas
- 6.8K Security
- 780 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
