USG210 VLAN-VLAN Speed-Problem
Tested with filecopy and TCP-IO-Tools.
With further testing, I was able to reproduce the problem with every constellation.
Within any VLAN, speed is perfect, but once I put the same machine into a different VLAN, the speed drops to almost 1/4 of Gigabit-Speed.
Without BWM and APD, there is a slight gain of 30 Mbit.
Memory is always around 60%, Sessions around 1.500 and CPU at 3%.
The only noticable "reaction" of the Zyxel during filetransfer is a rise of the CPU to 10%.
The only neccessary rule is a Security Policy Route, allowing VLAN-VLAN-traffic.
Hi @John_A
The performance will different when testing by different PC.(if PC performance is better, the result will be better)
But 280Mbps is very close to test result.
If in multi-sessions scenario, the total performance will higher than it.
5
Hi @John_A
Speed is perfect when client and server are belonging to same VLAN.
It is because the traffic is forwarding on switch directly but not forwarding to USG.
If you move server to different VLAN, the destination are belonging to different IP subnet so the traffic will route by USG.
USG will check the IP header and route to correct destination, so the CPU loading will higher than before.
As your test scenario, transmitting the traffic by 1 session the performance is very close to test result.
Thanks for the reply, Stanley.So, if I understand you correctly, my 280 MBit/s for InterVLAN-Speed is already the maximum for one session?0
Hi @John_A
5
- 3K Nebula
- 231 Nebula Ideas
- 6.6K Security
- 680 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 309 Service & License
- 502 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
