USG FLEX 500 - lan1 to lan 2 and lan2 to lan1
Smartmob
Smartmob Posts: 10
image  Freshman Member
Hello I have a firewall usg flex 500 with lan 1 (192.168.0.0 GW 192.168.0.230) and lan 2 (192.168.33.0 GW 192.168.33.230) for both lan the GW is the firewall itself
I need to make the two lan's and consequently the clients talk by enabling ips control
I can ping the firewall from both subnets on ex: 192.168.0.190 --> 192.168.33.230 but I can't ping client to client 192.168.0.190--> 192.168.33.100
I have tried state route and policy route but to no effect. What am I missing?
  • valerio_vanni
    valerio_vanni Posts: 157
    5 Answers First Comment Friend Collector Fourth Anniversary
    image  Master Member
    You don't need to add routes, those destinations are included in "direct route".
    You could look at the logs, to see if some other firewall rule blocks traffic.
  • Smartmob
    Smartmob Posts: 10
    I see nothing from the firewall logs.
    Only if I enter a policy control (lan1 to lan2) I can see the ICMP pass as accepted even though I still receive unreachable from the client.
  • valerio_vanni
    image  Master Member
    It could be remote device that doesn't respond.
    What kind of device are you unable to ping? PC, printer, etc…
    PeterUK Posts: 4,818
    image  Guru Member
    edited October 2024
    likely a firewall on end device
    unless you have enabled "Use IPv4 Policy Route to Overwrite Direct Route" ?with routeing rule like LAN1 next hop WAN?
  • Smartmob
    Smartmob Posts: 10
    is a server with dual ports 1) with the subnet 192.168.0.179 the 2) with the subnet 192.168.33.100
    And I am trying to ping the second port from a client under subnet 192.168.0.x
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,220
    image  Zyxel Employee
    Hi @Smartmob,
    It seems like your client is using Windows OS. Have you disabled the Windows firewall before testing?
    And if 192.168.33.230 can ping to 192.168.33.100?
    Zyxel Melen
  • Smartmob
    Smartmob Posts: 10
    Yes, the firewall is deactivated.
    Indeed it seems that from 192.168.33.230 I cannot ping the .100
    but I simply set a static ip
  • valerio_vanni
    image  Master Member
    Inside 192.168.33.x LAN you have only that host (.100)?
    Don't you have something other to ping?
