Reboot remotely a LTE3301-Q222
I'd like to be able to reboot remotely a LTE3301-Q222 via Wi-Fi but I cannot figure out how to do that. I tried to connect with telnet but I don't know the password. I tried the default password and the admin password but none of them work.
How could I do that?
If you forget password that you changed before, you have to reset the device to default via HW button. It means all settings on your device will back to default mode.
I didn't forget the password. This password works to login to the Web interface but doesn't for the telnet interface.The prompt shows:RT305XL login: admin
Login incorrectRT305XL login: root
Password:
Login incorrect0 -
Finally I restart the router in HTTP with http://192.168.1.1/log/in?un=admin&pw=1234&rd=/uir/rebo.htm
- 235 Nebula Ideas
- 6.7K Security
- 732 USG FLEX H Series
- 374 Security Ideas
- 57 Wireless Ideas
- 7.1K Consumer Product
- 319 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 117 Security Highlight
