Console stops working if you access with wrong speed
PeterUK
USG FLEX 200H V1.31(ABWV.0)
So if you run PuTTY to the FLEX with wrong speed set you get a mess then when you run with the right speed 115200 it fails to work needing a reboot of the FLEX to fix.
Update
This issue has been addressed and will be fixed in the next firmware release.
Zyxel Melen0
Hi @PeterUK,
I can reproduce this issue. Let me check with our engineer and I will update you once I have further information. Thanks!
Zyxel Melen0 -
Update
Zyxel Melen0
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
