[2025 Feb Tips & Tricks] Seamless Synchronization for Effortless Management
Zyxel_Avani
Zyxel_Avani Posts: 54
image  Zyxel Employee
edited May 2025 in Security Highlight
Simplify your network management with the new USG FLEX H series feature!
At Zyxel, we are dedicated to enhancing your network's security and management efficiency. With the latest uOS1.31 firmware for the USG FLEX H series, we've streamlined your user experience across both the local GUI and Nebula cloud management.
What's New?
The new uOS1.31 will automatically sync changes made via the USG FLEX H series' local GUI to the Nebula cloud.
For example, if you create a set of objects in the USG FLEX H series' local GUI:
Then, uOS will automatically synchronize the objects settings to the Nebula cloud, allowing you to see the exact same set of objects in the Nebula portal:
Get Started
  1. Upgrade Firmware: Ensure your device is running uOS1.31.
  2. Initialize Sync: Access the Live Tool page in the Nebula portal and click "Config Override" to enable configuration synchronization.
Experience a simpler, more efficient way to manage your network with Zyxel's USG FLEX H series and Nebula. Upgrade now!
