NWA55AXE Pole Mount Kit
SkyGoat
SkyGoat Posts: 44
First Answer First Comment Friend Collector Fourth Anniversary
image  Freshman Member
Is the NWA55AXE outdoor access point compatible with the ACCESSORY-ZZ0106F pole mount kit?
Best Answers
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,169
    image  Zyxel Employee
    Hi @SkyGoat,
    No, NWA55AXE is not compatible with the ACCESSORY-ZZ0106F pole mount kit since the screw design. In addition, the antenna of NWA55AXE is omnidirectional, therefore, you don't need this mount kit to help adjust the antenna angle, which is the main purpose of this mount kit.
    Zyxel Melen
  • Zyxel_Melen
    Hi @SkyGoat,
    I apologize for the delayed reply I was checking with our product team.
    The answer is 100 meters. The NWA55AXE is designed with an omnidirectional antenna, primarily for expanding wireless coverage rather than establishing long-distance point-to-point connections. Given the 1KM distance between the two buildings, this setup is not suitable, as omnidirectional antennas are not optimized for focused, long-range transmission.
    Zyxel Melen
  • Zyxel_Melen
    Hi @SkyGoat,
    It is the same as NWA55AXE, 100 M. In addition, this range is the maximum range with the Zyxel antenna. You may reach a further distance if you change with a directional antenna.
    Zyxel Melen
  • Zyxel_Melen
    Hi @SkyGoat,
    Zyxel Melen
  • SkyGoat
    SkyGoat Posts: 44
    edited February 2025
    @Zyxel_Melen
    Thanks Melen.
    What is the maximum range of 2 NWA55AXE's operating in wireless bridge mode?
    I have a two buildings 1km apart that I would like to bridge.
  • Zyxel_Melen
    Hi @SkyGoat,
    Zyxel Melen
  • SkyGoat
    SkyGoat Posts: 44
    @Zyxel_Melen
    Thanks Melen.
    What is the range of two WAX655E in wireless bridge?
  • Zyxel_Melen
    Hi @SkyGoat,
    Zyxel Melen
