port led switch gs1920 off
DarioVedovati
in Switch
Hi i'm working on new switch gs1920 i did the configurazione but when i put the cable in any port i can't see the led on everythink seems work correctly.
There is an option i can look to enable it?
Hi @DarioVedovati,
Please check the following troubleshooting items:
- Physical Connections: Double-check that all cables are securely plugged into both the switch ports and the connected devices. Ensure there are no bent or damaged pins on the connectors.
- PoE Mode Button (if applicable): Some GS1920 models, particularly the PoE versions, have a button that toggles the LED display between PoE status and link speed. Ensure this button is set to display link speed.
- Loop test: Connect two ports as a loop to check the port functionality.
Zyxel Melen0
- 244 Nebula Ideas
- 6.9K Security
- 800 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 328 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
