USG60 - Problem with internal LAN.
Good morning,
I have a strange behavior with our USG60 regarding the local LAN port.
Since we changed the network provider every time the provider's router reboots (power loss, random reboot, manual reboot, etc.), the USG changes the internal LAN IP mask. Something that it never had done in the past.
To give you an overview on the USG60 WAN 1 (P1) port is connected to the provider's router (an ADB VM 5722) with the "classic" 192.168.1.1/24 IPs pool.
On P6 is connected to the local LAN with the same IP pool (that's a "heritage" of the past) 192.168.1.1/24. The goal was also to "hide" the actual router by the firewall.
The ports IPs are static.
Pretty easy. Nothing too fancy.
But, as I said, as soon as the router reboots, the LAN1, on the USG60, changes from 192.168.1.1/24 to 192.168.10.1/24 and that forces me to log in, revert the change, and reboot several PCs/components of the LAN because everything is not working anymore.
Before we changed the provider, I had basically no issues. Or, at least, not so "bad" and, honestly, I don't know WHY this is happening and how to fix it.
Except to permanently change the local LAN IP mask and create proper rules in the firewall to forbid the router from reaching it.
I'm using the latest firmware:
Thanks a lot in advance.
Best regards
Giacomo
Hi @gia_az,
Using the same IP subnet on WAN and LAN could cause issues. I suggest changing the LAN IP subnet to be different from the WAN interface.
Zyxel Melen0 -
I see. Thank you.
I think I'll change the provider router to a different IP subnet as soon as possible because changing the internal one will take more time and effort and it will be a bit trickier.
Thanks again for the kind reply!
Best regards
Giacomo0
- 244 Nebula Ideas
- 6.9K Security
- 807 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
