USG FLEX H: Device stops responding after few weeks
szn
szn Posts: 21 image  Freshman Member
USGFLEX H 100, V1.31(ABXF.0)
Device is in production since beginning of November. The issue showed as first time after 46 days of running (v 1.30).
In mid-January device was upgraded to V1.31 and restarted. After 57 days (today) it stopped responding. Same symptoms as first time.
Observations:
-during a restart the memory utilization is 60% and it grows steadily and few days ago it was around 82%
-when device stops responding it is not accessible from network, restart button had to be used
-no events in Nebula log that could indicate what is happening
-as this is in a remote location i was not able to check what is on console access
Any suggestions?
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,033 image  Zyxel Employee
    Hi @szn,
    We have a date code firmware that fixes some memory issues. Would you like to upgrade and test? I will send the download link to you via private message.
    Zyxel Melen
  • szn
    Thx. Yes I will do the upgrade.
