Zyxel NWA130BE wap is stuck in "Power mode Limited" even with POE+
I've had this for a while and was using it with a POE switch. It was always complaining of limited power but was still working okay. I decided to get a standalone POE+ injector rated to 30W (which is more than the 24W on the specs) but it still is in "Limited" power. I can override it but I don't think that I should need to. Am I missing something?
I did this because I've noticed that sometimes it seems to stop working on my cellphone or devices and then will again. I assumed it might be because of that power warning but it's still thinks it's "limited" even though it has a dedicated POE injector now.
Any help would be appreciated!
Looks like it was an incompatible switch and injector. So, if you're having these issues, be sure to double check that your equipment actually supports the standards that it says it does.
- 244 Nebula Ideas
- 6.9K Security
- 804 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 330 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
