How to Set Up Nebula Hub-and-Spoke VPN and the USG FLEX H series model as the Spoke site?
This example shows how to use the Nebula firewalls (USG FLEX/ATP series models) to establish Hub-and-Spoke VPN tunnel between USG FLEX H series devices. It explains how to configure the Nebula Site-to-Site VPN using the Nebula Control Center. Once the Hub-and-Spoke VPN tunnel is established, LAN hosts can communicate with each other through the VPN tunnel seamlessly.
Set Up the Hub-and-Spoke VPN settings on the Nebula Firewall
On Nebula Control Center, navigate to Side-wide > Configure > Firewall > Site-to-Site VPN > Configure the Primary interface, Secondary interface (backup interface), on the local networks, enabling the interface will require routing through the VPN. Enable the Nebula VPN and choose the Hub-and-Spoke VPN topology and ensure that the USG FLEX H series is set as the Spoke site.
USG FLEX/ATP series site
USG FLEX H series site
Verify The VPN connection
Navigate to Side-wide > Firewall > VPN connections to check the site-to-site VPN connection was connected successfully on both sites.
Navigate to the Web-GUI path VPN Status > IPsec VPN > Site to Site VPN of the USG Flex H series model to check the Nebula VPN connection was connected successfully.
- 244 Nebula Ideas
- 6.9K Security
- 800 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 328 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
