NWA50AX as Wifi-Client - wired devices are not reachable within the Network- why?
Friendly hello to the community,
i have two NWA50AX Pro as (wired with router) AP to provide site-wide wifi-access. Now i wanted to use a NWA50AX (normal version) as a wifi-client to provide network-access to wired devices. All AP's are managed via nebula basic, have fixed IP-adresses and SmartMash and MLO is on.
I have two SSID's one is always on for fix devices, the other ist time-scheduled off (as guest-network for mobile-phones) - i have deactivated the guest-network and layer2-isolation for testing purposes. That has to be reconfigured, since the problem is solved.
(to get better understanding of the connections:
router - connected to wired devices and POE-switch via LAN-cables to AP's (50AX Pro)=primary network - connected via wifi to AP (50AX) - connected via cable to a switch and then to other devices /-/ these are not reachable via other devices at the primary network or from the internet.)
A mobile device, wich has a connection to the AX50 is functional, but not the wired devices. I know, the AX50 are not suitable to bride-mode, but as a normal client, i thougt they connect also to wired devices.
What do i have to adjust to get this functional? - (Or is it simply not possible with my AP's?)
Thank you and sorry for my poor english ;-)
Chris_gr
Hi @Chris_gr,
NWA50AX and NWA50AX PRO don't support the wireless bridge function.
Since then, you can't give the NWA50AX LAN client network access.
You can check the device function table to find the supported AP.
Zyxel Melen0
Hi @Chris_gr,
Zyxel Melen0
- 244 Nebula Ideas
- 6.9K Security
- 804 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 329 Service & License
- 537 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
