Difference between XGS1930 and XGS1935
We would like to add a second, similar switch to our current XGS1930. (Replace even older one)
It appears that the XGS1935 is a direct, functionally identical replacement.
Is that correct, or are the XGS1930 and XGS1935 functionally different?
"Lite 3" functions are important to us. And non-cloud management.
Thank you very much for your time and reply.
Best regards.
Hi @ZYXELSAML ,
The XGS1935 succeeds the XGS1930 with enhanced hardware while maintaining the same functionality, so it can serve as a direct replacement for the XGS1930.
Zyxel_Judy
Hi @ZYXELSAML ,
Zyxel_Judy
Thanks a lot, Judy.
Have a nice day.
Best regards,
Petr0
- 244 Nebula Ideas
- 6.9K Security
- 807 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
