[USG FLEX H]Intranet traffic have issue need to disable secure-policy as workaround.
Zyxel_Kevin
Zyxel_Kevin Posts: 988
Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
image  Zyxel Employee
Symptom:
There's an access issue between LANs or VLANs; ping and UDP traffic is working, only TCP have problem.
Solution:
Typically, this is because the connection did not establish on Firewall. The SYN-ACK reply isn't being observed on the firewall interface.
We can't disable this mechanism. This behavior is unusual for most security devices, please check your network topology/routing
Checking:
1)Enable debug level of "Security Policy Control"
2)You will see lots of log "Invalid state detected DROP" regarding to your source /destination
