How to troubleshoot Internet connection issues with Tailscale and USG FLEX H as Exit Node?
Zyxel_Emily
Question:
Answer:
If you're experiencing issues with internet connectivity while using Tailscale with the USG FLEX H as an exit node, follow these steps to resolve the issue:
- Ensure the Exit Node is Enabled:
Log in to the Tailscale portal, and verify the exit node option is enabled for the USG FLEX H device. Refer to "Case 2: Allow Client A to Access Internet through Firewall" in the USG FLEX H Handbook. - Disable Tailscale DNS Settings:
On the Tailscale client, go to the settings and uncheck the "Use Tailscale DNS settings" option. Test the internet connection again to see if browsing websites is now functional.
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
