Help finding product Zyxel XGS1930-10
Hello!
I would like to buy a multi gigabit switch with at least 8 ports with RJ45 ( each port with 100/1000/10000 mbps speed).
The seller offered me “Zyxel XGS1930-10” and he said that this one meets the specs that i need.
Does this product exist ? Because all that i can find is the “Zyxel XS1930-10”
Thank you!
Hi @cteit,
You're right — the XS1930-10 is the model that meets your requirement for multi-Gigabit RJ45 ports, as shown in the screenshot below.
Zyxel Tina
Hi @cteit,
Zyxel Tina
- 243 Nebula Ideas
- 6.9K Security
- 793 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
