How does Port Advisor work?
Port Advisor monitor your switch and alert you with these anomalies:
PoE Detection
PoE Detection
Trigger Criteria
PoE Overload
| When PD requests power exceeding the maximum power the switch is allowed to provide
Example: Switch port 10 settings include PoE maximum power at 15 watts. IP Camera connects to port 10 requesting 19 watts. |
PoE Short Circuit | When switch detects a short circuit from connected device |
PoE Power Management
| When total PDs requested power exceeds the switch’s power budget.
Example: Switch power budget is 300 watts. 10 access points connected under switch requires total power requirement of 301 watts. |
Storm Guard
Storm Guard
Trigger Criteria
Broadcast Storm
| Occurs when broadcast packets received by a switchport exceeds the Broadcast Limit (pps) settings.
Example: Switch port 10 settings include Broadcast Limit at 100 pps. Switch port 10 receives 101 broadcast traffic within 1 second. |
Multicast Storm
| Occurs when multicast packets received by a switchport exceeds the Multicast Limit (pps) settings.
Example: Switch port 10 settings include Multicast Limit at 100 pps. Switch port 10 receives 101 multicast traffic within 1 second. |
Bandwidth Pulse
Bandwidth Pulse
Trigger Criteria
RX Bandwidth Usage Exceeded
| Occurs when switch receives traffic on port utilizing more than 85% of the port’s link speed
Example: Port 10 establish link at 1Gbps. Traffic received on this port has peaked at 901Mbps. |
TX Bandwidth Usage Exceeded
| Occurs when switch transmit traffic on port utilizing more than 85% of the port’s link speed
Example: Port 10 establish link at 1Gbps. Traffic transmitted on this port has peaked at 901Mbps. |
Note: Bandwidth Utilization threshold can be manually set under Alert Settings page.
Loop & BPDU Guard
Loop & BPDU Watch
Trigger Criteria
Loop
| Occurs when loopguard packets sent by this switch was received in another of this switch’s port.
Example: Switch’s port 10 has loopguard enabled. Devices connected under switch port 10 forms a ring without the necessary network ring solutions. |
BPDU
| Occurs when switch receives a BPDU packet on a switch port with BPDU guard enabled.
Example: Office switch’s port 10 has BPDU Guard enabled. Client connects his personal switch with STP enabled under the office switch’s Port 10. |
Cable Health
Cable Health
Trigger Criteria
Poor Cable Quality
| Hit counter increases when either conditions have been met:
Note: Switches that fails to deliver these information to NCC accurately will produce inaccurate Port Advisor results.
- 244 Nebula Ideas
- 6.9K Security
- 801 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 329 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
