New in Firmware 1.35: Group-Level LED Suppression for Managed APs
Zyxel continues to enhance the usability of its AP Controller (APC) feature with the introduction of AP Group LED Suppression Settings in firmware version 1.35. This small but meaningful update gives administrators better control over the visual behavior of their access points (APs)—especially in environments where indicator lights may be distracting or unnecessary.
What Is LED Suppression?
LED suppression disables all LED indicators on your access points. This can be useful in:
- Schools and classrooms where lighting distractions should be minimized
- Retail or hospitality where visible lights may interfere with ambiance
- Bedrooms or dorms where constant blinking lights are disruptive
Previously, this feature could only be enabled per AP, but now you can apply it at the group level.
What's New in Firmware 1.35?
Group-Wide LED Suppression Setting
You can now configure LED suppression directly from the AP Group settings, allowing you to manage multiple APs at once.
- Found under: AP Controller > AP Group > [Group Name] > LED Suppression
- Options:
- Enabled – Turns off LED indicators on all APs in the group
- Disabled – Allows LEDs to function normally
Priority Behavior: Per-AP Overrides Group Settings
It’s important to note:
Per-AP LED suppression settings take priority over group-level configurations.
So if:
- Group setting = LEDs ON
- AP-specific setting = LEDs OFF
Then that individual AP’s LEDs will remain OFF, regardless of the group configuration.
How to Verify LED Suppression Status
You can confirm the LED status of each AP in the AP List:
- Navigate to AP Controller > Monitor > AP List
- Review the column showing LED status (ON/OFF)
This helps quickly identify whether suppression is correctly applied or if any overrides are in place.
Summary
Feature | Benefit |
Group-wide LED control | Apply suppression settings to multiple APs easily |
Visual distraction reduction | Ideal for quiet or aesthetic environments |
Per-AP priority logic | Offers flexibility for exception handling |
Easy verification | Status visible in AP monitoring list |
Whether you're managing a school, hotel, office, or retail space, this new group-level LED suppression setting provides a simple way to maintain a clean and distraction-free environment without managing individual devices manually.
- 244 Nebula Ideas
- 6.9K Security
- 803 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 329 Service & License
- 537 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
