Might be a big problem with FLEX700H SFP+ ports with V1.36 remote access VPN not being SNAT
PeterUK
PeterUK Posts: 4,753
image  Guru Member
edited October 2025 in USG FLEX H Series
Ooo I forgot enabled Two-factor Authentication😪
Dam thing had me going round in circles I think some indication on remote access VPN might help not make that mistake.
  • Zyxel_Tina
    Zyxel_Tina Posts: 1,030
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 250 Answers 500 Comments
    image  Zyxel Employee
    Hi @PeterUK,
    Glad to hear you’ve identified the root cause and your issue has been resolved!
    Regarding your comment, "I think some indication on remote access VPN might help not make that mistake," could you please provide more details or an example of what kind of notification or indication you feel would be most helpful for users? Your input will greatly assist us in reviewing and improving this feature to enhance user experience and minimize similar issues in the future :)
    Zyxel Tina
    image  Guru Member
    So on non H models there was a option to enable Two-factor Authentication in VPN gateway setting linking to the Two-factor Authentication page but the FLEX H only has one remote access VPN to enable but no where on the page does it show if Two-factor Authentication is enabled for it so just some linking indication that Two-factor Authentication is enabled would be nice.
  • Zyxel_Tina
    Hi @PeterUK,
    To better understand the difference you described regarding 2FA in the VPN gateway settings between non-H models and the FLEX H series, could you please provide screenshots of the relevant configuration pages? Having the information will greatly help us pinpoint the exact issue and assist you more effectively with your request.
    Zyxel Tina
    image  Guru Member
    like this of course on the FLEX H you can only make one remote access VPN so I guess they didn't think of adding the option yet.
