Simple GS1900-24E Vlan Config Problem
I'm new to my Zyxel GS1900-24E router so I'm probably missing something simple, but I can't see the DHCP server on my second VLAN and can't figure out why - so any help appreciated.
I am trying to setup two VLANs on the router.
VLAN1 (Home) is the default VLAN with port members 1-20.
VLAN2(Office) is the only other VLAN with port members 1 and 21-24.
So Port 1 is the only port common to both VLANs.
The network hub and DHCP server are connected to Port 1, and Port 1 is enabled for VLAN trunking.
Because Port 1 is a member of both VLANS, I think this means that I should be able to serve DHCP addresses to devices connected to either VLANs, but it only works for devices attached to VLAN1 ports and not VLAN2 ports.
All ports are set for 'Ingress Checking'; all ports are set for 'Untagged' data.
What am I missing or doing wrong. Thanks for all help and pointers.
John W
Hmm… I think the GS1900-24E is a switch rather than a router, and each switch port can only have a single PVID (native VLAN).
You’ve already proved that your device obtained a DHCP address from port 1, so its PVID must be 1. Therefore, to obtain a DHCP address from VLAN 2, you need to change the port’s PVID to 2 for your end devices.
A more advanced network setup that can meet your requirement would involve running a RADIUS server with 802.1X dynamic VLAN assignment on the switch. In this setup, the RADIUS server decides which VLAN each connected client belongs to. However, you will need to understand how to configure the appropriate rules on the RADIUS server."
Hi @NotoriousCanary,
Welcome to the Zyxel Community!
Here’s how to correctly configure your GS1900-24E to enable DHCP for both VLANs:
- Port 1 Configuration (Uplink/Trunk Port):
- For Port 1, configure it as an untagged member of VLAN1 and a tagged member of VLAN2. This allows VLAN2 traffic, including DHCP requests, to pass through with its VLAN tag, while VLAN1 traffic remains untagged.
- PVID Settings for Client Ports:
- For client ports 2-20 (VLAN1 Home), set their PVID to 1.
- For client ports 21-24 (VLAN2 Office), set their PVID to 2.
- Keep these ports configured to transmit Untagged data to end devices.
Zyxel Tina
0 - Port 1 Configuration (Uplink/Trunk Port):
Hi Zyxel Tina,
Belated thanks for your help.
DHCP is now being seen in both VLANs.
But - I've tried your setup and find that a computer connected on a VLAN2 port has full access to a network disc connected to a VLAN1 port.
I've tried turning on 'ingress checking' for all ports on both VLANs except for the shared Port 1, but that hasn't made a difference.
I've also set the 'Management VLAN' to VLAN1, but it seems I can log from VLAN2 connected computers.
So I think I am still missing something in the configuration that prevents communications between the two VLANS.
Any help gratefully appreciated.
Sorry for the late reply!
To troubleshoot the VLAN1/VLAN2 communication issue, could you please confirm if the uplink router has any policies blocking traffic between VLAN1 and VLAN2?
If no, add a blocking policy for VLAN1 ↔ VLAN2 traffic, then test again.
If the issue still persists, please provide:
- The device's current configuration file
- Your network topology
This will help us identify the next steps.
Zyxel Tina
- 243 Nebula Ideas
- 6.9K Security
- 792 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
