[USG FLEX H AP controller] What does the “LED Suppression On” feature do
Zyxel_HsinBo
Zyxel_HsinBo Posts: 532
Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - WLAN
image  Zyxel Employee
edited December 2025 in AP & Port setting
When the LED Suppression On feature is enabled, the access point will disable all front-panel LED indicators. This function is typically used in environments where visible LED illumination may cause distraction—such as hotel rooms, meeting spaces, or areas requiring a dark, unobtrusive installation.
The AP continues to operate normally, only the LED indicators are turned off.
