How to add NWA50BE PRO to USG FLEX 200 Wireless configuration
JJP
JJP Posts: 4 image  Freshman Member
First Comment Seventh Anniversary
Anyone able to guide?
NWA50BE PRO operational, in same (subnet) network, in Nebula. However want to add this AP into USG FLEX 200 Wireless configuration settings. (Do not want access details all over Nebula).
1 Internet search informs me that is should be possible, but unable to do so following that info.
2 Configuration - Wireless - AP Management - Firmware page shows 35 AP Frirmware listed SPs, none the NWA50BE. Does this point to the inability to integrate?
Anyone for a helpful suggestion?
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,079 image  Zyxel Employee
    Hi @JJP
    Because of the product positioning, NWA50BE/BE PRO can't be managed by USG FLEX 200 or 200H. The 50BE PRO management mode supports standalone and Nebula modes only.
    Zyxel Melen
  • Zyxel_Melen
    Hi @JJP
    Zyxel Melen
