My Switch died - can i return for repair or replacement
WLN_Net_Support
WLN_Net_Support Posts: 3
Fifth Anniversary
image  Freshman Member
  • Zyxel_Barry
    Zyxel_Barry Posts: 119
    image  Zyxel Community Virtual Assistant
    edited January 15
    Hi @WLN_Net_Support,
    I understand you're experiencing an issue with your Zyxel Switch and are inquiring about repair or replacement options. I'm here to guide you through the process.
    To determine the best course of action, please provide the following information:
    • Device Model: (e.g., GS1920-24, XGS1250-12)
    • Firmware Version: This can usually be found in the device's web interface.
    • Detailed description of the issue: (eg., What is the current LED behavior? Can you ping the switch's IP address? Any recent changes or events before it "died"?)
    • Network Topology Map: A simple diagram showing how your switch is connected to other devices.
    • Screenshots of any error messages or unusual behavior.
    In the meantime, you can check the warranty status of your Zyxel device by visiting the appropriate support link based on your region and entering your device's serial number.
    If your switch is determined to have a hardware issue and is still under warranty, you will likely need to initiate an RMA (Return Merchandise Authorization) request. The process for submitting an RMA request varies slightly by region:
    • For EMEA region: Follow the guidelines on the Zyxel Support Portal.
    • For US region: Use the provided link on the Zyxel Support Portal to submit an RMA request.
    Please note that Zyxel will no longer offer technical support, return, or repair services for products that have reached their End of RMA & Technical Support date.
  • electsystech
    electsystech Posts: 61
    First Answer First Comment Friend Collector Seventh Anniversary
    image  Ally Member
    It depends why it died, if it took a power surge or lightning strike, or physical damage, it won't be covered by warranty. Otherwise it should be if it's not EOL.
  • Zyxel_Tina
    Zyxel_Tina Posts: 1,019
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 250 Answers 500 Comments
    image  Zyxel Employee
    edited January 21
    Checking in to see if you've had a chance to gather the details Zyxel_Barry mentioned. Having those info will help us determine the next troubleshooting step to assist you with your switch.
    Zyxel Tina
