1.37 uOS - wrong default WAN selected inside NAT and VPN panel
GiuseppeR
Hello everyone,
when you want to open a port for a specific server you have to use NAT:
The problem is that the 100HP starts offering me always ge2:
that is a WAN offline:
I had the same issue with VPN panel where I had to set ge1 as primary interface:
If you use the on-premise UI everything seems smooth:
Is it a Nebula bug?
Hi @GiuseppeR
This incoming interface list order follows the external interface list order.
But here is different with the local GUI. I'm checking with our team, and I will update once I get further information.
Zyxel Melen0 -
Hi @Zyxel_Melen
it is strange that the ge2 interface is at first place on list order under "Interface" section.
If you look into WAN Status it is in the correct order:
How can I manage this interface order?
- 234 Nebula Ideas
- 6.7K Security
- 706 USG FLEX H Series
- 369 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 313 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
