SCR50AXE: Is it possible to set SSID with WPA3 + PMF required?
code5150ine
code5150ine Posts: 3 image  Freshman Member
In nebula control center, configure → SSID advanced settings
I have set the WPA3 to security option, but still my devices which can only find WPA2 SSID has access to router.
I also tried some kind of wifi scanner app on android and it showed information about my SCR50AXE´s SSID. It says WPA2/WPA3-Personal + Capabilities [RSN-PSK+SAE/SHA256-CCMP128] [WPA2-PSK-CCMP128] [SAE-H2E] [ESS] [MFPC]
So I think there is WPA2/WPA3 transition mode on?
Is it possible to switch the transition mode off and give it a WPA3 only with PMF required?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,938 image  Zyxel Employee
    Hi @code5150ine
    Yes, this is WPA3 transition mode on. Additionally, the default for WPA3 is enabling transition mode.
    If you need WPA3 with transition mode off and PMF, it is not currently supported because the transition mode option is not available on the configuration page. Please allow me to check with our team about the solution for you.
    Zyxel Melen
  • code5150ine
    Thank you for answering @Zyxel_Melen
    It would be great if an update includes mandatory PMF setting for Wi-Fi security in the future.
