Firmware
Den1304
Den1304 Posts: 4
image  Freshman Member
hello,
I’m looking for the latest firmware for gs1920-48 HP V1 (4.50 I think).
I cannot find it in discontinued product library.
Could send it to me at baudier.denis@free.fr
Thx
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,127
    image  Zyxel Employee
    Hi @Den1304
    Just a reminder, the GS1920-48HP model has reached its End of Life (EOL) status, which means our support for this model will be limited. For information on alternative options, you also can refer to the available models: Switch | Zyxel Networks
    Zyxel Melen
  • Zyxel_Melen
    Hi @Den1304
    Zyxel Melen
