Is Zyxel Wifi products affected by Airsnitch ?
Asgatlat
Asgatlat Posts: 140
First Comment Friend Collector Ninth Anniversary
image  Ally Member
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,273
    image  Zyxel Employee
    Update:
    This behavior is related to how WiFi networks operate. In scenarios where someone already knows the SSID password, there is a potential risk that may apply to common WiFi environments, including Zyxel deployments.
    To reduce the risk, we recommend:
    • Avoid sharing or exposing Wi-Fi passwords
    • Use stronger password and rotate credentials regularly
    • Use a VPN when accessing sensitive services over public WiFi
    We are currently reviewing this topic and evaluating possible improvements. There is no ETA at this time.
    Any updates will be shared in the WirelessLAN New Release section on Zyxel Community.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Asgatlat
    We are having a full investigation on this tool, and once we finish it, we will update here.
    Zyxel Melen
  • Zyxel_Melen
    Update:
    Zyxel Melen
