USG FLEX 500 speed
Fabio
Fabio Posts: 33
First Comment Seventh Anniversary
image  Freshman Member
we recently change our firewall with an USG flex 500
But we encounter a speed problem
we have several internet lines all are for 500mb/sec
but the speed sees the line has a very low upload speed.
This is not a performance of the line if we test with a different router the speed is correct
someon eknow how to solve it ?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,765
    image  Zyxel Employee
    Hi @Fabio ,
    To better assist you, could you please provide the following information:
    • Speed Test Topology: What is your speed test setup? For example, is your PC connected directly to the USG FLEX 500H?
    • Speed Test Tool: What tool are you using to perform the speed test?
    • Security Services: Are any security services currently enabled on the USG FLEX 500? If possible, please share your device configuration so we can review it.
    • Speed Test Results: What speeds are you getting during the test?
    Additionally, please note that the USG FLEX 500 has a built-in speed test tool. To use it, navigate to Maintenance > Diagnostics > Network Tool, select Speed Test, run the test, and share a screenshot of the results with us.
    Zyxel_Judy
