Port Advisor Enhancements and Intelligent Monitoring
Next-Generation Port Monitoring: Port Advisor Enhancements
Nebula 20.00 introduces significant upgrades to the Port Advisor to provide a more intuitive and manageable monitoring experience for network administrators.
The Usage Exceeding Bar
A primary enhancement is the introduction of the "Usage Exceeding Bar" for bandwidth and storm guard monitoring. Instead of traditional spike lines, Nebula now displays colored bars to represent traffic levels: green for RX and orange for TX. When a threshold is exceeded, a deeper color saturation highlights the anomaly on the graph. Administrators can mouse over these bars to see the exact time period the threshold was exceeded.
Average Rate Calculations
To reduce false positives from momentary spikes, the system now uses an average calculation over a 5-minute polling interval. If the average utilization during a 5-minute window exceeds the configured threshold, it is recorded as an anomaly.
If a device goes offline, NCC treats the missing data as a zero value rather than carrying over previous anomalies.
Recovery Notifications
To prevent excessive alerting, Nebula now utilizes "Recovery Notifications". When an issue is first detected, an alert email is sent. If the situation continues, the system suppresses further alerts until the entire interval is clear of anomalies, at which point a single "recovery email" is sent to inform the administrator that the issue is resolved.
Technical Considerations
Administrators using Loop Guard should note that if the Loop Guard timer is set longer than the email alert interval, the system may report false recovery alerts.
Additionally, the display unit for broadcast packets has been updated to "PPS (Packets Per Second)" for better technical accuracy.
- 244 Nebula Ideas
- 6.9K Security
- 800 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 328 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
