Why is the access point performance/speed different between standalone mode and Nebula mode?
Zyxel_JoyLee
Zyxel_JoyLee Posts: 218
Friend Collector First Anniversary
image  Zyxel Employee
The performance difference between standalone and Nebula modes on the AP can occur due to variations in firmware versions and radio settings.
Here are a few possible reasons and solutions:
  1. Firmware Version: Ensure the device is using at least firmware version 7.10p2 for optimal WiFi 7 performance. Update if necessary.
  2. Radio Settings: Verify that radio configurations in Nebula match the standalone setup:
    • Channel Width (e.g., 80MHz or 160MHz) and Channel Selection should be consistent.
    • Enable DCS (Dynamic Channel Selection) Client Awareness to avoid performance issues during channel scans.
  3. Security Service of Nebula: Disable security service(Site-wide > Configure > Access points > Security service) temporarily and re-test performance. It has been observed that disabling the security service can significantly improve the test results.
If further analysis is needed, enable Zyxel Support Access via Help > Support Request > Zyxel Support Access in the Nebula interface, and share your Organization and Site name with Zyxel support for deeper investigation.
