Conversion cfg. from Flex100 to Flex200H
QComp63
Is there a way to convert a configuration from Flex100 to Flex200H? Unfortunately, the Configuration Converter is not even able to convert cf. Flex100 to Flex100H
Hi @QComp63
Please try this method:
1.Remove these from the backup startup-config file.
! saved at xxxx-xx-xx xx:xx:xx
! model: USG FLEX 100
! firmware version: 5.42(ABUH.0)2. Select USG FLEX 200 instead of USG FLEX 100.
3. Upload the edited startup-config file and click convert.
Hope this helps.
Zyxel Melen0
Its not as bad as you think to have a working Flex100 you have access too to then configure a new FLEX H manually
Hi @QComp63
Hope this helps.
Zyxel Melen0
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
