[USG Flex H] - SNMP WAN IN/OUT octet wrong values
Hello everyone,
I've the USG Flex 200HP and if I try to query the WAN octet OID, obtain the wrong value.
The OID that I query is: 1.3.6.1.2.1.31.1.1.1.6.12 for WAN Incoming and 1.3.6.1.2.1.31.1.1.1.10.12 for WAN Outcoming.
Is this the right OID to query? My firewall is up&running from more that 14 hours.
Thank you
I found the problem... these OIDs were being used by the PPPoE_WAN connection before I configured a Tailscale VPN.
After configuring the VPN, the WAN OIDs changed, replacing the VPN (the OIDs used were therefore associated with the VPN instead of remaining associated with the WAN).
This shouldn't happen; it's not possible to configure new parameters, sections, and features and have the OIDs used moved.
Is this the case with you?
Also, if I were to create new VPNs in the future, would I find myself with the OIDs moved again?Thank you
Do you have any news about this problem? Can you open a case to the developer to not move the OIDs when I create new objects?
Hi @Maverick87,
Thank you for reaching out and providing the details.
I have forwarded this issue to the relevant team and will keep you informed of any updates as soon as they become available.
We appreciate your cooperation and patience.
Zyxel Tina
- 241 Nebula Ideas
- 6.8K Security
- 761 USG FLEX H Series
- 383 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 323 Service & License
- 522 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
