Why access points that do not allow WiFi connection to the phone and themselves?
Zyxel_JoyLee
This behavior usually happens because the two access points are interfering with each other, incorrectly configured, or creating a network loop/conflict.
The most common reasons are:
- Same Channel Interference
- Two APs nearby are using the same or overlapping WiFi channel.
- When one AP powers on, it creates heavy RF interference and clients cannot connect properly.
- Very common on 2.4GHz.
2. Duplicate IP Address
- Both APs may have the same management IP address.
- When one AP turns on, the other becomes unreachable or unstable.
3. SSID Security Mismatch
If APs broadcast the same SSID but: different passwords
- different security modes (WPA2/WPA3)
- different VLANs
then phones may fail roaming and disconnect repeatedly.
4. Power / PoE Issue
Sometimes enabling one AP increases power consumption:
- Switch PoE budget becomes insufficient
- Other AP shuts down or behaves abnormally
5. Loop in Ethernet Network
If APs are connected incorrectly:
- Ethernet loop may occur
- Entire network becomes unstable
- 243 Nebula Ideas
- 6.8K Security
- 781 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
