How to Resolve SSL VPN Connection Issues on USG FLEX H firewall?
Zyxel_Emily
in VPN
Question:
How to resolve SSL VPN cnnection issues on USG FLEX H firewall?
Answer:
If you are facing SSL VPN connection issues, such as constant disconnects and reconnects, follow these steps to resolve the problem:
- Check Two-Factor Authentication (2FA):
If 2FA is enabled under “User & Authentication > User Authentication > Two-factor Authentication > VPN Access”, ensure each SSL VPN user in the allow list is configured for 2FA (e.g., Google Authenticator). - VPN Configuration Adjustments:
Verify the SSL VPN configuration in the 'RemoteAccess_SSLVPN.ovpn' file. If it references a private IP (e.g., 192.168.x.x), change it to your public IP manually.
- 244 Nebula Ideas
- 6.9K Security
- 805 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 332 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
